Page 1 of 1
Permanent recording (not timlapse!)
Posted: Fri Jan 04, 2019 9:47 am
by xwing
Is there a way to configure C-MOR to record permanently? I do not mean the timelapse recordings. I want real time recording all the time.
Walter
Re: Permanent recording (not timlapse!)
Posted: Fri Jan 04, 2019 9:32 pm
by support
Hello Walter,
This setting is possible in the camera configuration menu:
Navigate to System Administration -> Camera Configuration -> Select Camera.
Scroll down in the camera configuration table to the configuration parameter "Recording Mode" and select "Permanent Recording":
- Video Surveillance Permanent Recording Setting
- video-surveillance-permanent-recording.png (48.86 KiB) Viewed 8615 times
Regards,
Posted: Thu Jan 10, 2019 6:47 pm
by xwing
Thanx! That works fine! But now I'm getting a lot of recordings which are 2 minutes long!
What can I do?
Posted: Tue Jan 15, 2019 6:47 pm
by support
There is another parameter,
Maximum recording time in Motion or Event Detection mode
Change this parameter e.g. to 600 to have 10 minutes long recordings instead of 2 minutes.
But, be aware, setting this value to high will cause that you alwas have to wait a long time even if you want to review a short time frame.
