Virtualbox annoying update notification
C-MOR Video Surveillance can run on a Virtuall Machine (VM). Feedback and infos can be found here. This completely free Video Surveillance VM packages supports all features of C-MOR for one camera. It available for VMware, VirtualBox, KVM, HyperV etc. It can be upgraded to a full version to support up to 15 IP cams.
fighter
Post by fighter »
Hello,
I'm running C-MOR on Virtualbox. Is it possible to disable the update notification of Virtualbox? Its annoying.
Tim
michaelr
Contact:
Re: Virtualbox annoying update notification
Post by michaelr »
Hi Tim,
Yes, it might be annoying and as long your Monitoring Software C-MOR runs stable there is not reason to install each update.
You can easily switch of the update notifiacation on a Mac VirtualBox installation:
Click on the VirtualBox Icon in the Dock
Select "Preferences" from the VirtualBox top menu
Select Update
Unmark the "Check for Updates" check box
Click ok and you should be fine
VirtualBox disable check for updates
Screen Shot 2014-09-14 at 15.51.43.png (61.62 KiB) Viewed 9897 times
Michael
Michael Reuschling
fighter
Post by fighter »
Thanx... I didn't think of a disable function for the update info....
Tim
