C-MOR on VMware
C-MOR Video Surveillance can run on a Virtuall Machine (VM). Feedback and infos can be found here. This completely free Video Surveillance VM packages supports all features of C-MOR for one camera. It available for VMware, VirtualBox, KVM, HyperV etc. It can be upgraded to a full version to support up to 15 IP cams.
C-MOR on VMware
The following documentation for installing the virtual C-MOR Video Surveillance Recorder on VMware was released.
C-MOR is up and running on VMware in a few minutes and is supported on the common virtualizated environment as there are VMware, Hyper-V, KVM and VirtualBox.
rudolpho
Re: C-MOR on VMware
Post by rudolpho »
Hello Forum,
I already installed C-MOR on VMware with the ISO image. Is there a difference to this version?
Rudolpho
Re: C-MOR on VMware
The VMware image has the Open VM Tools pre-installed so the VM could be fully managed by the VMware vCenter.
Hower, you can install the management tools manually any time.
Go to the System Administration -> Software Update -> Software Update and enter the update info for the Open VM Tools. Leave the update host unchanged, use "openvmtools" as user name and pasword, use the path /update/v5/opvenvmtools to install the upates:
Open VM Tools installation Video Surveillance C-MOR.
Open VM Tools installation Video Surveillance C-MOR  list files.
