Slow Camera in C-MOR Start Page
C-MOR Video Surveillance Support Requests
supportrequest
Post by supportrequest »
I'm having the following problem:
I call up the C-MOR start page or a camera page and with exactly one camera and always the same, the live stream shows up after a few seconds with a delay. All other live streams are displayed immediately.
What could be causing this problem?
Re: Slow Camera in C-MOR Start Page
Hi there,
this behavior can result from the camera setting "reduce stream speed in the C-MOR web interface". If this setting is switched on for the slow camera, the start of the live stream is also delayed:
Reduce stream speed in C-MOR Web Interface.
Reduce-stream-speed-in-C-MOR-Web-Interface-causes-slow-screen-start .png (29.23 KiB) Viewed 1480 times
This is the last setting in the "Camera Settings" table.
It is important that if the value has been set to improve performance, you should pay attention to whether the C-MOR is overloaded when switching off.
