Installing C-Mor to Disk
C-MOR Video Surveillance Support Requests
peterlang
Post by peterlang »
Am I right in assuming that this software is only designed to be run in a VM and not installed directly to an SSD hard drive in a 64bit PC. Several attempts at a direct install has ended in failure except for a Vbox installation. Some advice on this matter would be appreciated and a brief explanation if this is at all possible.
Re: Installing C-Mor to Disk
C-MOR also works as direct installation. C-MOR is sold as hardware solution in Germany. You may use the guides in the download section as reference.
We have a documentation in German only:
https://www.c-mor.de/videoueberwachung- ... -usb-image
There are some hints/screenshots (in English) which may be helpful. Basically you need to make sure the disks are detected propperly. Target disk as SDA and source USB stick/CDROM as SDB. Secure boot must be disabled in the BIOS.
Hope this helps!
Regards,
peterlang
Post by peterlang »
Yes I have had to go back to using a conventional HDD as my Nvme SSD is not recognised at all, so install fails. I thought that as the kernal was Debian based it would pick up the SSD driver but obviously those drivers are missing in the cut down version.
There is nothing cut and no drivers were removed. C-MOR runs fine on SSDs, we have frequent installations on SSDs.
